Sub soiler
9nKen
06-17-2002 21:49:55
Has anyone used a subsoiler to loosen up gravel? I plan to move a gravel parking space and am having no luck with my backblade or rockrake. The cost of the subsoiler is about a wash with a couple hours of backhoe work. Thanks for you thoughts,
Ken Molitor
Shaw Island, WA
Ed Gooding (VA)
06-18-2002 02:50:44
 Re: sub soiler in reply to 9nKen, 06-17-2002 21:49:55
Hi Ken. A subsoiler can probably get it loosened enough to use your back blade, but it could be a tedious process. A box blade with a stout set of scarifier teeth might be a better choice for this job. The scarifiers will rip up the packed gravel and the box will catch the loosened gravel and soil and allow you to transport to where you want to dump it. At the new parking site, you can raise the scarifiers out of the way and use the box to level the surface, then turn the box 180° to smooth and finish it.
fwiw..... ..Ed
'52 8N475798
Fast Ed Ohio
06-17-2002 22:34:17
I would say a good backhoe is needed , you dont know how deep or hard packed some of those larger rocks could be, that sub soiler just wont get it in most cases.
