12v Alternator question
Rusty (MS)
06-18-2002 08:35:34
When I got my 8N it had been converted to a 12v system. As best I can tell, I have the GM Alternator on mine as shown in the diagram at the Nseries websight Link My question is this. The P2 wire on my alternator is not attached to the battery pole as shown in the diagram. My P2 wire is about four inch's long and has been stripped naked on the end that would should attach to the battery pole. I was told by the guy I bought the tractor from that I needed to start the tractor, then touch the naked end of the P2 wire to the battery pole to polarize the alternator and start charging. When I do, the system starts charging as it should. Why is my P2 not connected to the battery pole and would it hurt anything to attach it? I always forget to touch the battery pole with the wire when I start working, but I didn't want to connect it until I was sure it would not harm my system.
Jim WI
06-19-2002 10:49:07
 Re: 12v Alternator question in reply to Rusty (MS), 06-18-2002 08:35:34
I suspect that you've got a one-wire version instead of the standard Delco 10SI.
According to a catalog entry that I've seen for these, it is sometimes necessary to momentarily touch a wire from either P1 or P2 to the BAT terminal to excite the alternator. You're only supposed to have to do this once but given the questions that keep getting asked about the one-wires, I suspect that tractor applications are a little different from those in old cars (generally the target market). Maybe it's because tractors generally run at lower RPM's.
I don't have an answer from my own experience because I used a standard 10SI on my 2N.
Brian *N* S. IL
06-18-2002 10:17:22
Rusty,
You can either attach the P2 lead to the battery OR just run a short wire over to the BAT terminal on the alternator. Either will work fine considering the short lengths of wire involved.
Take a look at my website for a complete wiring diagram if you want to check your system and make sure it was done right. The link will be down below.
If you have any questions, just email me, and we'll get it worked out.
Brian
Dell (WA)
06-18-2002 08:56:16
Rusty..... .....the P-2 terminal is the "remote sense" terminal. It is the way the internal voltage regulator figgures out how much volts output to pump to the battery to charge it. If it is not connected to the battery, the alternator outputs all the volts it can, UNREGULATED, this will boil out the battery and warp the internal plates and ruin the battery.
Most Delco 10-SI 3-terminal 12 volt conversions directly connect the BIG alternator output terminal to BOTH the battery AND the P-2 remote sense.
Its the P-1 terminal that provides excitation and can feedback voltage to the ignition coil and keep the tractor running and unable to stop it. This P-1 terminal is usually run thru an "idiot light" scheme like GM cars, like a marker light so you can excite the alternator so it will start charging and at the same time the light will allow you to turn off the tractor.
What is your P-1 connected to?..... ...Dell
geez dell....
06-18-2002 09:51:29
 Re: Re: 12v Alternator question in reply to Dell (WA), 06-18-2002 08:56:16
why dont you jump down his throat and tell him he needs the G_D DA_M 1/2 ohm and 10 watt resistor? By the way, the 12 volt kit i bought has a resistor..... do you think they ran to radio shack and bought up 100000 1/2 ohm and 10 watt resistors to make this kit? I doubt it very likely. Liek radio shack is the only place to buy a freakin resistor. Climb out from your hillbilly trailer and realize this is the year 2002 not 1952!!!!! !!!!! !!!!
because . . . Dell (WA)
06-18-2002 12:33:12
 Re: Re: Re: 12v Alternator question in reply to geez dell...., 06-18-2002 09:51:29
Durk..... .....because the question was about P-2 remote sense terminal on a 12 volt ALTERNATOR.
And because your question was about the necessity of using a 1/2 ohm 10 watt resistor with the 12 volt frontmount ignition coil. Which it is necessary, unless you want to continually be replacing $40 12 volt frontmount ignition coils. If you do, thats ok with me, just don't come complaining about why your 12 volt ignition keeps crappin out if you don't use the 1/2 ohm 10 watt resistor.
And because I've been in the Electronics Industry for 50 yrs, I know where and how to buy resistors, and it doesn't have to be Radio Shack, but it is a source for the electrially challenged that live in the outback, but that resistor certainally won't be available at a tractor parts store eather.
BTW.....you better be certain EXACTLY what that encluded resistor is used for in you kit and use it as the instructions tell you. Most big power resistors have their electrical values printed on them like ohms and watts. It might be important for future trouble shooting, you just might want to make a note.
OBTW..... ...power resistor smoke when they get hot for the first couple of times used, and they DO GET HOT, burnie.....burnie..... .respectfully, Dell
Darnit...I was soooo looking forward to that post...
06-18-2002 12:48:35
 Re: Re: Re: Re: 12v Alternator question in reply to because . . . Dell (WA), 06-18-2002 12:33:12
And you went a ruined it for me Dell.
I love when they ask why that 'thingy' is smoking...
Salmoneye
Think I'll trade my side-mount for.. Evil Steve
06-18-2002 13:37:56
 Re: Re: Re: Re: Re: 12v Alternator question in reply to Darnit...I was soooo looking forward to that post..., 06-18-2002 12:48:35
...a front mount and then convert it over to 12v. I'm just missin' out on so much fun! My 6v's gettin' boring. Never have any problems with it.
LOL. Keep the faith!
Evil Steve
Where did this Idiot come from? / Claus
06-18-2002 11:28:52
There was no question regarding coil resistors in Danny's post. Howsomever, Dell gave good advice and saw no rudeness in his response. Happy Motoring
Claus
don t. - 9n180179..Glad to see your posting again Claus...
06-18-2002 11:49:38
 Re: Re: Re: Re: 12v Alternator question in reply to Where did this Idiot come from? / Claus, 06-18-2002 11:28:52
...was hoping nothing bad had happened.
Danny in CO
06-18-2002 11:38:02
Claus,
FYI:
There were 2 post yesterday from the same guy (Durk, he used 2 different names, but the e-mail addr was the same) asking whether a resistor is needed with a 12 volt coil. Dell responded to each with the correct answer. Evidently, Durk took offense to Dell's tone in the responses and is taking pot shots at Dell now.
Danny
Danny in CO
06-18-2002 10:54:04
8nlover or Durk8nohio or durkster1@yahoo.com or whoever,
Dell gave you straight and correct info in each of his responses. Granted, each time with a little more bite.
12 volt conversion kits are not created equal! Side mount and front mount distributors makes the difference! A conversion kit for a side mount 12 volt coil does NOT need a resistor as I understand it. A conversion kit for a front mount 12 volt coil DOES need the resistor. I repeat, DOES NEED the resistor.
I hope this clears up your confusion and lighten up on Dell! He has volumns of knowledge and information that is valuable to this forum!
Respectfully,
Danny
no general rule here==bj/8n/mt
06-18-2002 11:11:57
 Re: Re: Re: Re: 12v Alternator question in reply to Danny in CO, 06-18-2002 10:54:04
Actually is ain't quite that simple. There are "twelve volt" coils that come with some side mount kits that do require resistors. Your best resource here is going to be either go off into the woods where nobody can see you and read the directions or call the kit vendor and see what kind of coil is included. Most frozen orange juice can style coils that actually do run on twelve volts are going to be marked something like "no external resistor required".
As far as I am aware all front mount "twelve volt" coils actually run on around seven volts and need a resistor other than the ballast resistor behind the dash which you want to disconnect.
Part of the joy of twelve volt conversions is there are so many ways to do it. Some of them even work.
Your mileage may vary
stupid is as stupid does==bj/8n/mt
06-18-2002 10:52:39
Coil dropping resistor is nothing to do with whether the alternator charges or doesn't.
Keep posting Dell. Some folks really want their questions answered.
Rusty 2N
06-18-2002 10:36:42
Well, GeezDell or no name whichever you prefer, I don't see where Dell was rude or nasty, thorough maybe but not rude. I have gained a bit of knowledge from Dell. You guys ought to lay off Dell or we are going to lose a good connection worth a ton of knowledge. Keep up the good work Dell, most of us do appreciate your input. Play safe. Rusty 2N
