1943 wartime-2n full set of steel wheels-mag?
9n141
06-21-2002 18:07:07
Bought this very nice 2n last fall @ an auction @ the farm of the original owner (98 years old). It has full electrics , where can I get a mag. & what else do I need ??
Scott
06-21-2002 18:35:39
 Re: 1943 wartime-2n full set of steel wheels-mag? in reply to 9n141, 06-21-2002 18:07:07
War shortage changes were done up until around serial# 9N120000, after that it had the electrical system again, it had a long front axle pivot pin that came out to the hole in the grille and used the early style set screw to hold it in, an oil filter return line into block right below filter like early ones, a short bracket mounted at the generator bolt hole to support the front choke rod, a 2 lever choke shaft in carb., a plug in starter button hole, a cover over the solenoid and starter holes, no ammeter, a short plug wire conduit, a fan belt idler bracket w/ pulley, when you find a mag and drive unit do not take it apart below the cap unless you are familliar with it so it doesn't get out of time, Dearborn 16-13 to 16-24 combines made in 1949 and 1950 had the same mag drive, the mag was a newer number but looks the same and the idler pulley will need alot of modifications because a combine did not have a front axle support in the way, the rear steel wheels on a 1943 had 28" center discs.
Hey Scott,front axle pin question...Jay 2NSC
06-22-2002 07:00:43
 Re: Re: 1943 wartime-2n full set of steel wheels-mag? in reply to Scott, 06-21-2002 18:35:39
Hi Scott,I have a 2N with the axle set up like you described.Do you know where I might find a picture or dimension's on this pin?Maybe I could get a machine shop to make a couple?Someone has a homemade pin made from a peice of pipe in it now and it doesn't look safe.Any information I would appreciate.:^)Thank you,Jay 2NSC
Scott
06-22-2002 11:59:34
 Re: Re: Re: 1943 wartime-2n full set of steel wheels-mag? in reply to Hey Scott,front axle pin question...Jay 2NSC, 06-22-2002 07:00:43
Jay, it will be hard to measure in the tractor and I don't know of any picture or exact dimensions, it almost comes out to the hole in the grille.
