Order Ford 8N Parts Online
Transmission Noise on 8N
Pedro
06-22-2002 17:19:34
While the tractor is running the transmission is making a whinning or whizzing noise. That doesn't sound usual. When you step on the clutch it goes away. When you let off, it comes back. Our other fords do not do this. The transmission has new oil. Has anybody had this problem before, and what can be done about it?
Rusty
06-23-2002 07:03:31
 Re: Transmission Noise on 8N in reply to Pedro, 06-22-2002 17:19:34
Got an 8n that is just like that. Not real sure what is making the noise. Been using the tractor and it has not caused a problem yet.
Hola Pedro==bj/8n/mt
06-22-2002 17:39:41
First a question: Does it do this with the power take off engaged and disengaged?
Next a best guess: Front bearing in the transmission is failing. Could last for years; could go bad tomorrow. You will need to split the tractor to fix it which is a lot of time and grunt work but not much in the way of parts.
If'n it were my machine I would live with it until it got a lot worse. Your machine your call.
Your mileage may vary
