Order Ford 9N Parts Online
Ford 9N, are they good?
robert
06-24-2002 12:45:19
Thinking about purchasing the neighbors 9N. Has a continental engine, looks like in good shape. Are parts available and are they any good?
Owen in teXas
06-24-2002 22:52:37
 Re: Ford 9N, are they good? in reply to robert, 06-24-2002 12:45:19
I too would like to know more about the 9N.In particular the 1942 model. I wanted a newer(1950-53 8n)tractor but I found this '42,it looks good and supposedly runs good and has been converted to 12v. The "ole gentleman" is asking $2500 which includes a 5' mower. The tractor has fairly new rear tires ,not weather checked).Sould I continue looking for the 8N ? What is there about the 9N that may or not be desireable. What was the paint colors?Thank you for any respones.
Owen
Lou V.
06-24-2002 15:23:14
Another hint re whether it really is a Ferguson is the starter. The Ferguson starter (on the TO-20 as far as I understand and perhaps other models) had the starter built in to the gearbox. In other words, you used the gear shifter to actuate the starter (I don't remember what position in the shifter pattern)
MikeC
06-24-2002 13:51:13
If it has a Continental engine then it's not a Ford. If it just has a flat head, then it probably is a Ford. Parts for all N tractors are easy to find. I've never had to look for parts for a Fergie.
Jim.UT
06-24-2002 12:51:18
The Ford did not use the Continental engine. You may actually be looking at a Ferguson. They look very similar and the Ferguson used the Continental engine.
Parts still available for a 9N, but not as plentiful for a Ferguson. Ferguson is a good tractor.
Look on the dash above the steering column. Is there an ID plate riveted there? What does it say?
robert
06-25-2002 16:46:07
 Re: Re: Ford 9N, are they good? in reply to Jim.UT, 06-24-2002 12:51:18
This tractor is a ferguson. Where do I find information on a ferguson? I see ford 9n, 2n, 8n and such. Is there rebuild information with the continental engine? The brakes are very strange and will need parts and a service manual to sort that out.
Jim.UT
06-25-2002 20:55:47
 Re: Re: Re: Ford 9N, are they good? in reply to robert, 06-25-2002 16:46:07
Go to the top of this page. See the word "Hop to:" next to a dialog box? Click on the pull down arrow and find "Harry Ferguson". Click on that, then click "Go". That will take you to the discussion forum for guys with Fergusons. Ask them your questions and you'll get better answers. Good Luck!
