Hey Zane
Rusty (MS)
06-25-2002 09:51:04
You may not remember, but I emailed you about a week ago about the lift on my 8N Ford. Thanks a lot for ALL the info you gave me. I think I'm going to mail you a money order tomorrow for a Zane Thang. I've got a 47 8N Ford. Any problem with putting the Zane Thang on it that you can think of?
ZANE
06-25-2002 18:39:53
 Re: Hey Zane in reply to Rusty (MS), 06-25-2002 09:51:04
The ZANE THANG will actually make the position control work better than the original 8N position control. More infinate in it's height increments.
If the draft will work, then the ZANE THANG will work just like it does on the Ns etc that don't have postion control.
Tom-Pa
06-25-2002 10:46:57
You can use one on the 8N if the position control is messed up/out of adjustment/worn pin etc. I did for 6 months till I was able to tear into the system to repair it. Then I put it on my 2N..
Good Luck
Tom-Pa
jimpCo
06-25-2002 09:57:35
rusty, you don't need a Zane Thing on an 8N. They are for the 2/9N's only for position control, which you already have.
Ken N Tx
06-25-2002 13:32:01
 Re: Re: Hey Zane in reply to jimpCo, 06-25-2002 09:57:35
It will also work on an 8N if the position control is not working....Ken
