Change gear oil
Al Maas
06-26-2002 09:08:08
I just got an 8N 2N or 9N Don't know what it is.... #on motor is Star 9N6167. It runs good, But I would like to change the gear lub. for the trans & hyd lift, My question is ware is the drains, How much dose it hold for a refill, And how do you check the current level of the gear oil??? Thanks Al
Jim/41_9N
06-26-2002 09:55:14
 Re: Change gear oil in reply to Al Maas, 06-26-2002 09:08:08
Al,
Drain ALL three drain plugs, starting with the SMALLEST. This allows you to start with a slow drain, otherwise 5 gallons comes rushing out the large hole VERY FAST.
Yea! MikeC
06-26-2002 10:44:07
 Re: Re: Change gear oil in reply to Jim/41_9N, 06-26-2002 09:55:14
If you start with the biggest one the oil tends to gush out all over your arms, bucket, creeper, garage floor, tools, etc. Don't ask how I know...
Scott
06-26-2002 09:48:59
It has a 1939 9N engine if there is another star behind the last number, the whole tractor is a 1939 9N if the starter button is on the left side of the dash. There are 2 large drain plugs under the tractor housing that takes an 1 1/16" wrench, you will need to get new gaskets for these when getting new oil, and 1 small square headed pipe thread plug under the rear end, it holds between 4 1/2 and 5 gallons depending how much sludge buildup is in the bottom, fill at the large plug beside the gear lever, this takes a gasket also, check the oil level either at the square headed pipe thread plug on the right side of the transmission or it may still have the dipstick beside the gear lever.
