49 8N cluth pedal bushing
what to do
Rick
06-30-2002 07:52:09
Has any one found a source for the bushing that goes inside the hole in the cluch pedal? I hope I can find one off the shelf rather than having one made. I haven't even pulled mine out yet so I'm not sure if the shaft or the pedal are also worn. What have you guys done to fix a sloppy clutch pedal bushing???? Your advise would be greatly appreciated.
don b
06-30-2002 09:06:51
 Re: 49 8N cluth pedal bushing - what to do in reply to Rick, 06-30-2002 07:52:09
The clutch pedal bushings,9n7508 and 8n7508 are not available as far as I know.We are having both made, and it should not be too much longer.We do have 40-7508 which goes in each side of the tranny housing for the clutch shaft. don
Rick
06-30-2002 11:51:01
 Re: Re: 49 8N cluth pedal bushing - what to do in reply to don b, 06-30-2002 09:06:51
Thanks Don, I'll keep checking your site
Ron
06-30-2002 08:08:00
Can you explain further what you mean by "bushing in the hole in the clutch peddle". There is no hole in the clutch "peddle". In fact there is no clutch "peddle" that I am aware of. Lots of clutch parts but no peddle. Check part nomenclature in manual or draw pic.
Rick
06-30-2002 12:08:52
 Re: Re: 49 8N cluth pedal bushing - what to do in reply to Ron, 06-30-2002 08:08:00
Thanks Ron, I was refering to the bushing in the clutch pedal (the thing you step on) that rotates on the brake cross over shaft. In Don's reply he said he will soon have the bushings available. Thanks again.
