NO OIL PRESSURE
Alan
07-02-2002 10:11:54
NO Oil Pressure... When I put the tractor away for the winter all was fine. The tractor started right up in the spring, however there wasn't any oil pressure. I checked the gauge, oil screen and even changed the oil. Has anyone had this problem before?
Mountainman
07-02-2002 17:36:38
 Re: NO OIL PRESSURE in reply to Alan, 07-02-2002 10:11:54
In addition to wear, the other possible reason your pump lost it's prime is the use of multi-grade(wt) oil. I have read on this board more than once that that is a prime suspect in pump priming problems (say that three times, fast). I use 40 wt and would use 30 wt in winter if I drove it much.
Hope this helps.
Mountainman...CA
Wayne
07-02-2002 17:09:32
I have had this happen on a couple of tractors after setting for a long time. I made up a device from a piece of larg dia pipe capped with an air fitting. I pour oil into the pipe, cap it, and put low pressure air to push the oil thru a convenient oil fitting back into the oil pump. It works every time for me. The problem is worn oil pump vanes.
CJ in Michigan
07-02-2002 11:37:30
Did you disconnect the gauge and line and crank it to check if there is pressure in the engine? It is a messy way to see if your gauge is the problem.
Phred MN
07-02-2002 10:46:07
I'll agree with Mike. Try repriming the line maybe some air got in there. I had that happen one time when it was real cold out.(-20F) I warmed it up with a heater then started it and the the pressure came up. I think it was condensation that had frozen in the line.
MikeC
07-02-2002 10:17:29
You might try priming the oil pump. On the front of the motor there is a large bolt head that houses the pressure relief valve (a spring). Remove the bolt (15/16ths I think) and squirt some oil (about 10-15 pumps) in the hole. Replace the relief valve and turn it over to see if you have pressure.
If this does not work I would look at the gauge or the pickup tube...
