Order Ford 8N Parts Online
8n change pully for dearborn loader
Paul P
07-04-2002 19:34:40
I am trying to change the front pully on my 8n tractor. I was able to get the front end on bolted (hood off as well) except I cant't get the control arms off the pitman arms. how do you get these to relase off the pitman arms? Ok so I tried to pull the front end forward enough to get a wrench on the pully nut but I can't get it to relase. I hope someone can help me with this, thanks,
Paul P
07-08-2002 17:16:39
 Re: 8n change pully for dearborn loader in reply to Paul P, 07-04-2002 19:34:40
Just wanted to thank everyone for the help with this loader got everything in place and tested it today. Everything runs great! Roland Jackson are you the person who is selling the power steering kits??? By the way it's a Deerborn 19-71 loader
Scott
07-05-2002 10:20:34
Your New Holland (Ford) dealer has the special screw and lock washer to hold the pump drive pulley on.
Roland Jackson
07-04-2002 22:47:28
Paul, if you will unscrew the ball joint nut on the sector arm shaft about 3 or 4 turns (to protect the threads) then place a block between the nut and the transmission case and smack the sector arm, the ball joint will come off. It works the same on the other end where the drag link hooks onto the steering arm of the front wheels. Just unscrew, block and smack!
Dell taught me how to thread close line into a sparkplug hole and it works great! If you still have the crankshaft pulley bolt that has the catch for the hand crank, you will have to modify the bolt or go to a bolt supply store and buy the correct threaded bolt. Hope this helps.
Dell (WA)
07-04-2002 22:24:32
Paul..... .....Don't know why you think you need to pull the frontend off your N-Tractor to change the crankshaft pully. Get a socket that fits the crankshaft nut, putt it on. Then with a long extention, go thru the radiator shell and unscrew it, CCW.
BUT BIG TRICK..... . stuff a soft 1/4" clothesline rope into any sparkie and fill up the cylinder, then when you torque your crankshaft nut the rope will stop the crankshaft from turning and you can apply the full 150 ft/lbs to remove or install the crankshaft bolt that holds the crankshaft pully on its half-moon key..... .....Dell
