Sherman transmission -type of oil?
Pokey
07-06-2002 06:35:39
What type of oil should I put into my Sherman before installing it?> ? Thanks, Pokey
Dell (WA)
07-06-2002 06:44:51
 Re: Sherman transmission -type of oil? in reply to Pokey, 07-06-2002 06:35:39
Pokey..... ...use the same stuff you use in you tranny/hydraulics 5 gal reservour. They were shipped dry from Sherman and you need to fill it up for installation. 1 or 2 pints'll do it not too critical.
Howsomever..... you don't ever need to change or worry about changing Sherman oil BECAUSE your N-Tranny front gear has a "oil slinger" that actually pumps oil INTO the Sherman and keeps it topped off.
BE CERTAIN to replace the Sherman front oil seal, uses the same seal as your N-tranny $3 cheap..... ..Dell
