Let's put it this way, if you let this one slip through your fingers, you've missed a good opportunity that, more than likely, will not present itself like this again. Not impossible to find...but very difficult to find under your circumstances. If you let it slip through e-mail me (humor) :) Sounds slike the critical component...the block and hood are matched. When you check the aluminum dash...check for a serial number/patent numbers tag/plate riveted on the upper steering column. If not a black painted thin gauge tag there, then there should be a number cast directly into the top of the casting there. Also, am interested to know the keyswitch location. Also, where is the transmission dip stick located? on the tranny cover? or inspection plate? For that vintage...look on the tranny cover. The smoothy hubs were susceptible to loosening up, and were replaced with the improved hot riveted rear hubs. They can be acquired. More than likely, your steel wheels may not be original to the 9N637. There is a fella in the classifieds selling a smooth hub 9N, cast aluminum dash cover, small generator, cast aluminum horizontal bar grille, and CM HAll lights for 4300-4500.00 bucks. 9N 637 is more desirable for the collector point of view. If you can acquire this tractor for less than that, you've done well. The grille? you say horizontal bars? would that be cast aluminum? If that's the case...it is 'correct' to the early 9N tractor. Later production (mid year 40 and on) tractors the grilles were steel with vertical bars. I'll be happy to help you search and find parts as will many others here. good luck. 9N'er
