3 rings or 4? How 'bout some of each??
OKRon
07-09-2002 19:44:56
I am putting the engine back together with a rebuild kit. I got the old sleeves out, new sleeves in, crankshaft with new bearings and I've been having a great time, but this is weird. I had ordered 3-ring pistons with my sleeves. The boxes all indicated 3-ring pistons were inside, but as I removed the sleeves I noticed that the pistons were 4-ring. Oh, well, I thought, I'll just go with it. It turns out that 3 of the pistons are 4-ring, but one of them is 3-ring. Does anyone see a problem with using this combination? The old pistons were 3-ring, but they are worn pretty bad and can't be re-used.
The archives have been a great help in this project, but I didn't see this situation mentioned there.
Thanks,
OKRon
MARK H IS RIGHT!... Evil Steve
07-10-2002 08:12:32
 Re: 3 rings or 4? How 'bout some of each?? in reply to OKRon, 07-09-2002 19:44:56
Do not use the combination. Those 3 cylinders that would have 4 rings will have higher compression. It will make those three have to "carry" the 3-ring cylinder and just ends up wearing out every cylnder too early.
Think of riding a bike with one sore leg. Your good leg has to work harder to take up the slack and wears out sooner than it otherwise would. No material difference in an engine.
That is exactly why Ford specs say that compression differential across the cylinders should not exceed 10%.
If you can, return the 3-ring for a 4-ring. There is no appreciable increase in coeffecient of drag using a 4th ring and you get higher compression for longer time. Just don't use too heavy oil (not > 40wt) so that oil can circulate well enough to the rings.
Consider yourself fortunate for that vendor mistake even if you have to buy that 4th 4-ring piston.
Danny in CO
07-10-2002 06:58:55
My opinion:
I don't see, technically, why it would matter if you had a mixture of 3 ring and 4 ring pistons. Each sleeve shouldn't care. It might even be a good experiment. Tear it down in 30 years and see which sleeves had more wear:^)
However, if it were mine, I would exchange the 4 ring pistons for 3 ring ones and use all the same. It would just look better!
My $.02 worth,
Danny
Mark Hendershot
07-10-2002 08:33:41
 Re: Re: 3 rings or 4? How 'bout some of each?? in reply to Danny in CO, 07-10-2002 06:58:55
I know a Volkswagon engine is differt but if you put a heaver piston in one cylinder you will feel the engine shake at higher rpms. You try to get them with in 5 grams or less of weight of each other for a good balance. I have rebuil a few of these and have felt the differance in the engines. Now I weight the piston and rods to make sure they are the same or very close. Maybe it won't make a differ on the low RPMs but I would'nt do it just to find out. Mark H.
Mountainman
07-09-2002 21:24:21
Seems to me I remember seeing that discussed here before and the concensus was that three rings were plenty. It was said that the fourth ring only added friction.
You ought to be able to return the wrong parts for exchange.
Mountainman...CA
Mark Hendershot
07-09-2002 19:49:15
If it were mine I would want all one or the other and keep the engine balanced. Mark H.
gary
07-09-2002 19:55:52
 Re: Re: 3 rings or 4? How 'bout some of each?? in reply to Mark Hendershot, 07-09-2002 19:49:15
ditto
