The loader is a Ford 19-200 Loader. The bucket also has a Ford tag on it too. It is a rugged loader and in really good shape. The seller was going to remove the loader and sell it separately. He had some offers on it and so I said 1,000.00 for the loader. It looks to be in excellent shape. Not a single weld, crack, bend or poor pin etc. It's really tight and the Vickers pump boosts that thing up fast. I was going to find one of these anyhow for the down pressure; an advantage over my older Dearborn pipe frame loader. So, all in all, the loader and tractor came in at 4700.00. I am learning all of the time, and for some reasn I had it in my head it had live PTO until Jim(UT) made the same comment on the Ford discussion board. A quick check proved it to be non-live PTO and that makes sense. I wish I knew all there was about everything and not show off one of my greatest talents: ignorance. The front drive transfer case is an unique set-up. It comes out of the left inspection plate to a differnetial and then the long shaft to the front differential. If you look carefully, there is a box over that assembly to protect the driver and his legs or pants from getting wrapped up in the turning parts. I'll post some close-up photos as I remove the rear end and take that assembly apart. Yes, Tony is very knowledgeable and he worked on my 850 when I had it. Perhaps someday I'll sell it but for now I'll keep it. It needs a lot of work but overall, the engine is in good shape. It just needs a thorough going-over and going through. After I look at it and think about it, this tractor defines the term "tractor" I mean, this is a tractor. tom
