Order Ford 8N Parts Online
Axle pin shims/'49 8n
Rick/Kansas
11-27-2000 18:30:19
Just replaced the axle pin bushing. Also, put in two more shims on the back side of the axle pin to take up slack. This caused the radius arm ball to fit tight in its socket since the shims forced the axle forward. With the engine jacked up the axle moves freely against the shims. My question is whether it is OK to have the radius arm ball fit so tight. I expect the shims will wear down and everything will loosen up. Or, should I take out one shim? Thanks
DaBrow
11-28-2000 05:08:26
 Re: Axle pin shims/'49 8n in reply to Rick/Kansas, 11-27-2000 18:30:19
It sounds like your support assembly {#3029}was wallowed out. {oversized}
