Sickle mower
Alan Arvin
07-25-2002 14:45:19
My neighbor will sell me his 3 point sickle
mower for 75.00.Its a model 14-93 according
to the tag on it-its a Ford brand.The universal
joint on the back end is worn out bad.Where
can i get a u-joint that will fit reasonably
priced.I believe it is a 6 spline shaft,made to fit a 8n or naa tractor which i both
have.Thanks for your help guys.Alan
Jim.UT
07-26-2002 09:57:36
 Re: sickle mower in reply to Alan Arvin, 07-25-2002 14:45:19
I don't know where you are, but my local FNH dealer has never failed to come up with the driveline parts I have needed for implements. Splined hubs, u-joints, yokes, square tube, you name it. Give them a try. Helps if you take the old part with you in case they need to take some measurements.
Fast Ed Ohio
07-25-2002 22:10:24
My Uncle had a 3 legged dog after using one of them sickle mowers, keep the kids and pets penned up till your done mowing .
Mountainman
07-25-2002 21:10:41
In CA in the SF "East Bay area" there is a company called Drive Line (Many franchises) that repair and custom make just about any shaft and joint arrangement - car, truck, tractor, PTO shafts and all types of U-joints, CV joints etc. I had them make up custom drive shafts for my 4x4.
Might be someone in your area that does the same thing. Happy N ing.
Mountainman...CA
Dave Manley, NY
07-25-2002 15:17:12
That is a fair price I just paid $200 for the same mosel last weekend. The one I bought didn't need anything and works great but for $75. and a U joint I would say you got a bargin.
worth a try==bj/8n/mt
07-25-2002 15:08:53
I tried Ford New Holland for u joints for two different Dearborn sickle mowers and didn't find either. The one you talk about sounds like a later model and they may still support it.
I got a u joint for a Dearborn 14-16 at a local auto parts house. U joints are fairly generic and if you can get the counter person to spend the time they can most likely find it. Take the whole joint in--cross and cups--and be charming. Worked for me at Carquest but bet it wouldn't work at one of the discount places. Good luck
Your mileage may vary
