Order Ford 8N Parts Online
8NBrake Drum
RayOh
07-29-2002 07:01:11
How Do You Get The 4 Screws Out That Hold The Brake Drum To The Hub On A 8N?I Want To Put Brakes On.I Could Pull The Axel But I Still Need To Get The Drum Off.Soaked With PB Blaster Two Days & Used Heat. Still Wont Move. Thanks
Ray Oh
07-29-2002 17:38:19
 Re: 8NBrake Drum in reply to RayOh, 07-29-2002 07:01:11
I Loosened The Brake Shoes & Found The Impact Driver I Forgot I Had & It Broke So I Drilled All Four Of Them Out & It Still Didnt Come Off So I Loosened The Big Nut In The Middle & It Came Off With One Hand.Not The Way It Says In The Manual But I Can Have The Other Side Off In Fifteen Minutes Now.Thanks
Wayne
07-29-2002 08:54:15
Ed is right on...If the impact screwdriver don't do it, drill them out and forget them. They are only on there to hold the drums on during the tractor assembly line. I have had them so rusted tight that it was impossible to remove them.
Willy-N
07-29-2002 11:01:09
 Re: Re: 8NBrake Drum in reply to Wayne, 07-29-2002 08:54:15
I haven't had to drill one out yet but have remove many with taping them on the outside edge to break the rust loose. That way you can screw another one back in to keep the hole filled and original if needed. Mark H.
bill
07-29-2002 18:58:43
 Re: Re: Re: 8NBrake Drum in reply to Willy-N, 07-29-2002 11:01:09
I took a chisel that looked right and drove the screw notch backwards for a couple turns.. worked for me..
Willy-N
07-29-2002 08:17:35
I grind a punch flat on a angle so that it can hit the side of the screw slot and knock them loose and then unscrew them. Mark H.
Paul R.
07-29-2002 12:06:32
 Re: Re: 8NBrake Drum in reply to Ed Gooding (VA), 07-29-2002 07:40:45
Ed, "whang" is a not so obscure colloquialism, listed in Webster's as "To strike as to produce a loud, reverberant noise.", so its use is quite correct. I recall the great Chuck Yeager used it to describe the action of closing the hatch on the X-1, even though he had several busted ribs at the time....(grin).
