Stump the experts...
Rick H
07-29-2002 20:25:43
I knew that'd get your attention. hehe..
So...I'm tearing apart my engine getting ready for a rebuild. Got it all apart and am inspecting the block, when something catches my eye that looks unusual. With the block in the upright position on the engine stand, I can see into the holes in the water jacket between cylinders 2 and 3, a loose piece of metal just kinda free floating in there. It's maybe the thickness of a welding rod, and shaped like a square with one other piece running accross. What the heck is that? It's totally loose, with no way out, and no way in?? Is this some piece left over from the original casting? First one to answer can have a glass of my own homebrew. You'll have to come over here to get it though, it doesn't ship very well.
Rick
Ken N Tx
07-30-2002 13:54:50
 Re: Stump the experts... in reply to Rick H, 07-29-2002 20:25:43
In Fla. its call a Dangling Chad.....
George Willer
07-30-2002 10:32:24
Rick,
You found the remains of a chaplet...a support for a sand core to hold it in place until the metal was poured. They are often left in place after the shake-out process. Part of it was surrounded by molten iron and is part of your block.
George Willer
jag
07-30-2002 00:20:21
Every ford engine casting iv'e seen (100+) has this its just part of the mold/casting. Remember the plastic dodads that people found in their ford auto trans the first time they changed the fluid. It was just a shipping plug that closed off the dip stick hole until the dip stick tube was installed!!! Boy if I had a dollar for every one of those that was brought to my shop and I had to tell them what is was.
Allen in Oregon
07-29-2002 20:47:11
It is probably Casting flash but I am not sure.
As a side note I still have a #2 pencil with general motors stamped on it That came out of the water jacket of my wifes 283 chevy pickup motor when it was overhauled. It still has the yellow paint on it and was still fairly sharp. (:>)
Good luck with your rebuild.
