Coil...Again.......Not Really
Alan
07-31-2002 12:53:27
After consulting the board I thought I had one of those flaky coil/ignition sw problems last week...but just to make sure I removed the carb and took it home to check out...after reading all the posts on mice getting into everything I stuffed paper towels up the air breather tube as well as the manifold tube...Returned to the tractor , put carb back on and continued to check electrical stuff out....Defintely had "no sparkies " ....Coil OK..Replaced Ignition Switch...Still "no sparkies"...I had just finished hogging and apparently a samll piece of chaff got into the points...cleaned and readjusted and she started right up ....except I could not get full RPM or power....Sat back and cussed for a few moments and then promptly removed mice proof packing from breather tube...I was amazed that she started up at all with that stuff in there.....All went well after that...Thanks again...Alan
