Hydraulic problem-could this be a relief valve gone bad?
back40
08-01-2002 05:17:30
'51 8N - About a month ago I parked it with the bush hog lifted up in the air and it took a little over three hours for it to drop to the ground. Now after only a couple of hours mowing, it drops down to the ground within about 5 minutes. I hooked up a post hole digger last night(which weighs a lot less than the bush hog), raised it up, turned off the pto and drove a little ways across the bumpy barnyard and all of the sudden the digger just dropped instantly to the ground. I thought I might of heard a "pop" a fraction of a second before it happened. Turned the pto on, lifted it up again, turned the pto off, then the same thing happened. Could the relief valve have gone bad?
Phil (VA)
08-01-2002 06:47:30
 Re: Hydraulic problem-could this be a relief valve gone bad? in reply to back40, 08-01-2002 05:17:30
Yeah, that's a prime suspect.
