Tranny identification
Allen in Oregon
08-02-2002 15:58:51
I bought a 43 9n today, not running and I need to I D the auxillary transmission. I has a shifter on the left side with a plastic knob at the top. It seems to have 3 positions 1 forward, 1 center, and 1 back. Is this a Hupp? Should center position be neutral or is this an over and under? Thanks in advance. Allen
John
08-03-2002 07:59:03
 Re: Tranny identification in reply to Allen in Oregon, 08-02-2002 15:58:51
Allen, It sounds like you have a sherman overdrive. foward on the shifter is standard drive middle is nuetral and back is overdrive.Most hupp auxillary transmissions are on the right and the handle moves up/down. And most parks are cable operated. Most of the parts for a sherman are still able to be found. However parts for a hupp or parks are a little harder to come by. Hope this helps. John
Levi (WA)
08-02-2002 22:17:42
third party image
Here is a good place to find out what you have.
