Brake shaft 2N
Rusty 2N
08-03-2002 18:14:19
I need to replace/ straighten the shaft that the left peddle mounts to, is this shaft removeable? Is that a pin at the plate end?
Tyler (MD)
08-04-2002 07:00:47
 Re: Brake shaft 2N in reply to Rusty 2N, 08-03-2002 18:14:19
Never took it apart but I believe I did see a some sort of pin to hold the brake camshaft in the plate. The other end just pulls right out as you pull the backing plate, etc., away from the tractor.
Tyman
Willy-N
08-04-2002 08:58:56
 Re: Re: Brake shaft 2N in reply to Tyler (MD), 08-04-2002 07:00:47
The 8N uses a pin on the Cam and also has a key on the pedal side, if they are close to the same you would have to remove the single pedal first and take the key out of the shaft and shove the shaft out with the other parts on it. Then you could put it in a vice to drive the pin out of the cam on the other side. Mark H.
