Zane I got live thang installed
Allen in Oregon
08-11-2002 19:25:23
I got the live thang installed and am very happy with it! I am having problems with the lift being jerky, I have got a new relief valve to install and then I will adjust the lift with your jig. It has been too hot and smokey to do any work out here so I will have to wait untill the forest fires are out. Thanks, Allen (;>)
ZANE
08-12-2002 04:28:06
 Re: Zane I got live thang installed in reply to Allen in Oregon, 08-11-2002 19:25:23
The lift should not be jerky when the PTO is not turning because the LIVE THANG pump is a gear pump and should not be pumping intermittently like the belly pump can.
Does it jerk when both pumps are running or when the PTO is disengaged????
If it is semething caused by the LIVE THANG this is a new one on me and I'd like to know what the problem is so get back to me when you have a chance to evaluate it.
I see on TV that you are having lots of wildfires out there. Hope that they get them under control soon.
