Coil problems
Andrew Nuckolls
08-12-2002 09:25:41
i was wondering do you have to replace the coil if you put in a 12 volt system and if you want to convert back to 6 volt do you have to replace it
Claus
08-12-2002 09:58:07
 Re: coil problems in reply to Andrew Nuckolls, 08-12-2002 09:25:41
You can keep the old coil as long as you use a voltage dropping resistor in series with the ballast.(front mount, angle mount does not use an external ballast) These are available at our sponsors.
Happy Motoring
Claus
