Going Crazy In Alabama
Rusty
08-12-2002 17:52:48
Just changed a head gasket. The tarctor was running fine but it was forcing water out of the radiator. Then it would overheat. Now it will not crank. Got compresion but have sort of weak spark on 1, 2 cylinders. When you take a plug out of 3 or 4 the tractor will run for a few seconds. Any ideas? Replaced about everything but the points. They may need to be replaced, but the tractor ran fine before the head gasket change.
bg
08-13-2002 07:12:05
 Re: Going Crazy In Alabama in reply to Rusty, 08-12-2002 17:52:48
This is not an Allis-Chalmers WC, is it? Seriously, is it a front-mount or side mount distributor?
Dell (WA)
08-12-2002 19:37:20
Rusty..... ....check your spark plug wiring for correct firing order. 1,2,4,3 CCW..... ....Dell
