Draft control spring
RPP9N
08-13-2002 11:45:50
Has anyone found a good way to free up a rusted draft control spring? The yoke threads into the spring coupler. To try to adjust it while rusted results in poping the yoke off the draft control spool valve, which is a pain to hook back up. Has anyone tried pouring Coca Cola on the spring?
Gary R.
08-13-2002 18:37:14
 Re: Draft control spring in reply to RPP9N, 08-13-2002 11:45:50
use oxy/accetylene to heat the yoke. make it glow.put a bar through the yoke & work it back & forth. (as far as the heat goes get on & off asap,)ID rather heat it than tork on it
Bob E
08-13-2002 17:06:22
Soaked mine with PBX for about a week with no results,heated it up with a torch and it came right off.
Mountainman
08-13-2002 12:00:57
Haven't tried Coca-Cola but I would soak it in MMO and your favorite penetrating oil for several days. Tap on it occasionaly and add MMO and pent oil often. I guess if that doesn't work you may have to apply heat.
Mountainman...CA
