Order Ford 8N Parts Online
8n Manifold studs
Rick/Kansas
12-04-2000 18:08:26
Anyone have a secret to removing manifold studs?
I have one that is eroded, still usable, but the hood is off and I'm debating on taking the chance that the stud can be removed without twisting off.
Only thing I know is to put a wrench on it and hope it pops loose, or stop the pressure before something breaks. Any advice will be appreciated.
Beekeeper
12-05-2000 06:52:48
 Re: 8n Manifold studs in reply to Rick/Kansas, 12-04-2000 18:08:26
A method I have used for several years to remove "stuck" bolts is to heat the bolt up with a propane torch until its somewhat glowing and then swab beeswax around it (a beeswax candle works well if you do not have a block of beeswax). The beeswax literally sucks itself into real tight places and will coat the threads of the bolts. You may have to reheat and repeat.
yep.....Dell (WA)
12-05-2000 11:39:34
 Re: Re: 8n Manifold studs in reply to Beekeeper, 12-05-2000 06:52:48
Beekeeper..... can't understand why you would recommend "beeswax" (grin) but I will testify that your beeswax trick really does work..... ..Dell
Jim K
12-04-2000 18:14:12
Heat and WD-40 with a little tenderness
Jim K
