Proofmeter Cable RPM
PHoban
08-22-2002 05:00:34
The Question: What is the ratio between the Proofmeter cable RPM and the Engine crankshaft RPM?
The Story: I finished rebuilding the engine on my 52 8N and installed a new cable on the proofmeter. The proofmeter looks like an original and probably hasn't had a working cable on it in years (maybe decades). The engine runs fine but the proofmeter seems to be indicating higher than actual engine RPM. I have adjusted the engine idle to where it just barely turns over and the indicator shows 900 RPM. I hooked a mechanic's electronic RPM meter to a spark plug wire and I get eratic readings from 27,000 to 0 RPM (Yes, I mean 27 Thousand not Hundred). The mechanic says his meter works fine on modern cars but the spark strength in the old tractor is just too different to give an accurate reading. My idea is to hook an electric drill, of known RPM, to the proofmeter cable and see what the proofmeter reads. What I don't know is, does one RPM of the tractor engine equal one RPM on the proofmeter cable. It wouldn't suprise me if the gearing in the govenor and various gears reduces the actual cable RPM and the proofmeter is calibrated/marked to show engine RPM and not actual cable RPM. Or... I could just skip all of the investigation and proofmeter rebuild fun and buy a new proofmeter. But Hey, this is a hobby, not a job. I like tinkering with stuff. The object is to have fun while learning something, not to spend money. Besides, the tractor runs fine no matter what the proofmeter says.
bg
08-22-2002 06:17:54
 Re: Proofmeter Cable RPM in reply to PHoban, 08-22-2002 05:00:34
Does the needle return to to "0" when the tractor is turned off, or does it just drift around? There is a bar inside that adjust the clockspring tension to calibrate the proofmeter. The clockspring may be broken, or the induction magnet may be dragging on the disc. The drill should give you a fairly accurate reading.
PHoban
08-22-2002 06:29:44
 Re: Re: Proofmeter Cable RPM in reply to bg, 08-22-2002 06:17:54
The needle returns to zero.
Have you (or anybody) ever attached a known RPM drill to the cable and read the same RPM on the proofmeter?
bg
08-22-2002 08:04:19
 Re: Re: Re: Proofmeter Cable RPM in reply to PHoban, 08-22-2002 06:29:44
yep. Since the induction magnet spins inside the driven disc and the clock spring holds the needle back, either one of two things is happening:
The spring is weak, or the induction magnet is dragging the disc due to rust or gunk or corrosion. The magnet is not supposed to touch the disc, it just barely clears the edges, and the magnetic force pulls the disc around, moving the needle. There ar two type of proofmeters, the AC and the King-Seely. The King Seely is more cheaply made and has a different calibration set up.
