Follow-up on only runs when choked
PickeringRick
08-23-2002 18:35:39
Thanks for all the responses. I checked first to see if the carb was gettin fuel. Barely a drop. After blowing out the line from the bowl to the carb, I took the outlet from the tank off, and found sediment in the opening for the reserve portion. The problem was that I didn't have much fuel in the tank, and since the reserve opening was clogged, I wasn't getting fuel to the carb. Drained what was left, put in fresh gas, and had her running for about 1/2 hour. So far, so good.
Thanks again, Rick
YT Group
08-24-2002 19:57:00
 Re: Follow-up on only runs when choked in reply to PickeringRick, 08-23-2002 18:35:39
Thanks for letting us know we were of help!
