Oil Pump pickup
Al
08-25-2002 15:43:39
I'm looking for an oil pump pickup tube for a 9N. I haven't been able to check with my parts man to see if he can get it, but I haven't seen them for sale online. Does anyone know if there available???? Thanks, AL
AL
08-25-2002 18:45:39
 Re: Oil Pump pickup in reply to Al, 08-25-2002 15:43:39
Thanks. How can I tell which one I have and need??
Scott
08-26-2002 05:04:00
 Re: Re: Oil Pump pickup in reply to AL, 08-25-2002 18:45:39
Measure the gear width inside the pump, the small pump has 9/16" wide gears and large pump has 3/4" wide gears.
Al
08-26-2002 17:35:46
 Re: Re: Re: Oil Pump pickup in reply to Scott, 08-26-2002 05:04:00
Thanks again, I have the 9/16"
Scott
08-25-2002 18:34:41
The tube for the large pump is still available from New Holland (Ford) (50 lbs max pressure cold) or if it still has the small pump you must find a used one (30 lbs max pressure cold).
