Generator commutator got attacked by 80 grit
prentice
08-26-2002 18:52:33
Is this a problem. I took the generator, 6v to a shop and the guy cleaned the commutator with really rough sandpaper. My recollection is you almost polish that surface with fine emory cloth. Do I need to resurface it now? Generator works, it did when I took it by for checkup, they and I didn't know that. Prentice
Wayne Mo
08-26-2002 20:05:40
 Re: generator commutator got attacked by 80 grit in reply to prentice, 08-26-2002 18:52:33
You should sand it smooth with lighter sandpaper or emery in order for your brushes to last longer. You are not supposed to use emory or sandpaper but you can, just clean it up so no particles are left and clean out the grooves too. If it works now, you will be ok.
