Order Ford 9N Parts Online
Appreciate all of the replies on the 9N Neutral Safety Sw). I even got the tractor working! Thanks again!!!
Andrew Stephens
08-29-2002 06:23:10
Thanks a million!
JES
08-29-2002 06:53:31
 Re: Appreciate all of the replies on the 9N Neutral Safety Sw). I even got the tractor working! Thanks again!!! in reply to Andrew Stephens, 08-29-2002 06:23:10
What did you end up doing?
Andrew
08-30-2002 08:44:54
 Re: Re: Appreciate all of the replies on the 9N Neutral Safety Sw). I even got the tractor working! Thanks again!!! in reply to JES, 08-29-2002 06:53:31
Well...after I checked, cleaned, lubricated the switch, it still didn't work. Then, checking through the electrical system...I found...a poor connection to the battery!
thanks for follow up . . . Dell (WA)
08-30-2002 10:39:44
 Re: Re: Re: Appreciate all of the replies on the 9N Neutral Safety Sw). I even got the tractor working! Thanks again!!! in reply to Andrew, 08-30-2002 08:44:54
Andrew..... .thanks for follow up. Sometimes the obvious, isn't..... ..Dell
