Serial number
Arthur Moore
08-29-2002 17:27:39
Would like to know where to find the serial number on a 8n
JimNC
08-29-2002 18:08:27
 Re: serial number in reply to Arthur Moore, 08-29-2002 17:27:39
Right here
third party image that is, if it has not been changed out for a power unit that had no ser #. You may have to use a lot of elbow grease to remove years of paint and grime to see it.
Arthur Moore
08-29-2002 18:31:31
 Re: Re: serial number in reply to JimNC, 08-29-2002 18:08:27
Now what year would my tractor be my serial#is 8n52177
Jim.UT
08-29-2002 19:29:02
 Re: Re: Re: serial number in reply to Arthur Moore, 08-29-2002 18:31:31
I could tell you, but you'd miss out on the fun of discovery. See the column of links to the left on your screen? Click on the one that says "Serial Numbers". Then click "Ford", then click "8N". Bingo! Now you know.
ALLEN in Oregon
08-29-2002 19:27:38
That would be 1948. If you look to the left under research and info you will see "serial numbers".
Click on that and then ford and then 8n.(;^)Allen
