Order Ford 8N Parts Online
'48-8N radiator pressure.
George
08-30-2002 09:04:12
Before I started the restoration of my '48-8N I used it quite a bit for light logging. I worked it hard when needed and let it idle between use. I never had a problem but noticed it never really got very hot. It also never seemed to build up much pressure (going by the hose squeeze test). The coolant level always leveled off at about 3" below the top of the radiator. The thermostat is new and installed in the correct direction. The cap is also new. Question - Does the above sound normal or should I expect an appreciable pressure buildup? I'd like to address potential problems before I put everything back together.
Perfectly Normal- Evil Steve
08-30-2002 09:14:52
 Re: '48-8N radiator pressure. in reply to George, 08-30-2002 09:04:12
3" beow top of radiator is correct. While these ARE pressurized systems, it isn't high pressure like in automobiles.
