Charging System
Russell Arnold
08-30-2002 20:32:02
How do i tell if my 8N is positive or neg. Ground ????
Wayne MO
08-30-2002 20:38:59
 Re: Charging System in reply to Russell Arnold, 08-30-2002 20:32:02
Look at which battery cable is connected to a ground and which is connected to the starter solenoid.
Dell (WA)
08-31-2002 00:33:45
 Re: Re: Charging System in reply to Wayne MO, 08-30-2002 20:38:59
Russell..... ...what Wayne said..... ...
You do realize that batterys have molded-in plus (+) sign for positive don't you? Connect that one to chassis for positive ground. Make certain that you "polarize" your 6 volt voltage regulator.
If your tractor has been converted to 12 volts, the internal solid state gutts demand negative ground or you will experiment with semi-conductor fuses and do not polarize a 12 volt alternator system, ever..... ....Dell
