TSX 33 Carbs
pat woodruff
09-01-2002 18:06:02
Guys, I'm embarassed to ask this but can someone (Zane, Dell, Dave....)tell me where the jets go on the TSX 33 carb? I know there is one at the bottom of the nozzle, and I see the idle jet but is there one at the bottom of the power adjusting needle? It kind of looks like there is one when I look at the FO-4 manual but the parts kit instructions are unclear and like an idiot I failed to make notes when I disassembled this last winter.
Gaspump
09-02-2002 06:35:27
 Re: TSX 33 Carbs in reply to pat woodruff, 09-01-2002 18:06:02
The TSX 33 carb has 3 jets, Idle, economiser (both in the top of the carb) and the power jet (in the bowl casting). Both jets in the top should be easy to spot. The link below shows the power jet nicely.
Dave Smith
09-01-2002 18:24:28
Pat, Go to the link below. I think you will find what you need there. Click on Carb Rebuild.
Dave <*)))><
boo
09-05-2002 17:28:48
 Re: Re: TSX 33 Carbs in reply to Dave Smith, 09-01-2002 18:24:28
