Safety relief valve for ford jubilee
rick finney
09-02-2002 04:15:52
I am looking for a safety relief valve for my naa ford jubilee tractor. this is not the relief valve but the safety relief valve that is located by the cylinder under the seat. if any one has got one or can tell me where to get one, I would sure appreciate it. thanks
ZANE
09-02-2002 19:42:15
 Re: safety relief valve for ford jubilee in reply to rick finney, 09-02-2002 04:15:52
You should be able to get one at a Ford/New Holland dealer.
Did you take the relief valve apart to see if it had any foriegn material in it? Sometimes this will happen and cause them not to hold. I have also had some sucess fixing them by using a wooden dowel and valve grinding compound to reshape the seat and replacing the ball with a new one. Also make sure that the spring is not broken.
Zane
