Noise in the hydralic lift.
Ron from Ohio
09-04-2002 18:39:39
Hello all while I was hogging the other day i noticed upon lifting my mower that the hydraulic lift has developed a noise, grind something. The noise is rythmatic almost like a rod knock in a engine. Any ideas? And yes the fluid is the correct spec and level. Thanks
RAVI
09-05-2002 09:58:28
 Re: Noise in the hydralic lift. in reply to Ron from Ohio, 09-04-2002 18:39:39
I HAD THE SAME PROBLEM. ITS FROM WEAR OF THE HYDRO PUMP. PURCHASED A REBUILD KIT FROM DONS
AND THE NOISE IS GONE.
Rick Ga.
09-05-2002 04:55:59
Hi Ron. I don’t know about a grinding noise but my 49 8N has made a knocking noise in the lift ever since I have owned it (26 years). The heavier the implement the louder the noise. From the information I have gathered over the years the noise is due to ware on the hydraulic pump. I have been told it will not hurt a thing. My lift works too good to worry about rebuilding the pump because of the noise. A couple of years ago I honed my lift cylinder and installed an NAA O-ring and replaced the relief valve. That strengthened my lift a lot and it holds for hours. But the knocking noise is still there. (check the archives) HTH. RickGa.
Keith (Ohio)
09-04-2002 20:24:05
What kind of tractor do you have? (9N-2N-8N-Naa)I have a 2N and it sounds like what mine sounds like when it gets low on fluid. I am sure you have already checked that? What part of Ohio are you from? I am from Ross County. Good luck with your problem. I had to rebuild my hydrolics, and it was not really all that bad to do.--Keith
Ron from Ohio
09-04-2002 20:36:22
 Re: Re: Noise in the hydralic lift. in reply to Keith (Ohio), 09-04-2002 20:24:05
Im from miami county Keith. And my tractor is a 1941 9N. Yes I have checked the fluid level and it is right up where it is suppose to be. Thanks
Ron from ohio
