Generator charging or not?????
Ron From Ohio
09-04-2002 18:54:44
Ok one more question my 41 9N's amp meter reads just 2 notches of positive charge at an idle but as the rpms increase the charge moves to the negetive side. ( way on the negetive side) Any ideas I have not checked anything yet and the belt is tight. And the cables all seam fine also. thanks
raytasch
09-04-2002 19:15:29
 Re: Generator charging or not????? in reply to Ron From Ohio, 09-04-2002 18:54:44
Sounds like the wire through the ampmeter loop is backwards. If you have lights, turn them on and notice if they get brighter when the engine is reved. Put a meter across the battery terminals and note voltage. Rev the engine and note the voltage. Lights brighter or voltage goes up, your generator is working.
ray
Dave Oh
09-04-2002 23:16:39
 Re: Re: Generator charging or not????? in reply to raytasch, 09-04-2002 19:15:29
Ray had all the right answers for you. I would have only one question for you. You are connected as a Positive Ground 6v System?
Dave OH
Bob in NY
09-04-2002 19:35:30
Just remember to turn off the lights! I was mowing yesterday, came in for supper, went back out, and she wouldn't start. Thought the starter was bound up, so I pulled it out. Very loose. Went back to the house and got a meter...then saw the light switch was on, and the battery was dead. DUH! Check simple stuff first!!
Gary '40 9N
09-05-2002 05:45:35
 Re: Re: Re: Generator charging or not????? in reply to Bob in NY, 09-04-2002 19:35:30
YUP, sounds like the ammeter is wired backwards.
Hope so! Bob in NY
09-05-2002 17:24:15
 Re: Re: Re: Re: Generator charging or not????? in reply to Gary '40 9N, 09-05-2002 05:45:35
The simple stuff will get you every time! Got me. Bob in NY
