Richard H
09-05-2002 20:01:12
Could you please help me out if you can, Could you please tell me what a compleat rear end is worth that looks new,it is in a tractor that was burned in a barn fire. New to this tractor thing,never owned one and don't want to get ripped off.Please help if you can. I'm talking about the whole Differential Assembly I guess,and I'll get the Pinion also. Also I can get the whole Tractor from the transmission back (the transmission Bell housing is busted but the gears and all where put in 3 months before it burnt). The wheels and tires or no good but the Hydraulic Pump and all is supposed to be good,and the axles and all are intact as well as the rear end. My ring gear sheared all 12 rivets that hold the ring gear to the Differential Case Half. And buggered up two teeth on the ring gear. And the Ring Gear rub against the PTO Shaft and Scared it some, this burnt tractor has one in it also. So if you can, a price on the whole Differential/Rear End,,, intact with all gears/and Case together.??? And then a Price from the transmission back as I described??? I know I'm asking a lot, and Know it would be hard with out seeing it, but please the best you can. If you all could help me with this,it will be very appreciated,,,Thanks in advance,Richard
