8 N keeps dieing
R Rahmier
09-07-2002 17:48:37
My neighbor has 8N ford that runs for awhile and then dies after it dies you can check for fire at the points and it has fire he has replaced coil points condenser cap rotor wires and plugs and it didnt help it seems like when it cools down it startswhich I thought sounds like condenser or coil. we replaced the condenser with a old one and it ran a little longer than before but then died again any ideas?
Polecat_VA
09-09-2002 19:23:07
 Re: 8 N keeps dieing in reply to R Rahmier, 09-07-2002 17:48:37
I had a similar problem with my 49 8N. My problem turned out to be a clogged fuel line. It would start and run until the fuel bowl in the carb was empty, and then wouldn't start back up until enough fuel trickeled back in.
greg
09-08-2002 11:41:02
We struggled with our 8N for a few years. It would run for about and hour then die. It would not restart until it cooled, or so it seemed. We tried every single ignition system component but nothing helped. then I noticed that the centrifugial mechanism in bottom of the distributor had a problem. The timing is advanced by the centrifugal switch. Our switch had come apart. The timing in essence could have been anywhere! In fact it caused the engine to backfire and damage the starter. I cleaned and repositioned the components and boy does the tractor ever run better! Pin in the mechanism had vibrated out of the slider slots and hung up the mechanism. good luck.
Marty B. KS
09-07-2002 18:56:07
I recently had the same problem and rebuild the carb and it was fine. I think it was related to fuel delivery. It would run fine for a while and then just die. After I could start it again within minutes. Rebuilt the carb and it had run great eversince.
Dave Smith
09-07-2002 18:02:35
When it dies check the ignition switch by jumpering around it. If it starts and runs replace the switch. A bad coil will also give that symptom and coils have been known to be bad out of the box.
Dave <*)))><
Richard l. Rahmier
09-07-2002 18:08:22
 Re: Re: 8 N keeps dieing in reply to Dave Smith, 09-07-2002 18:02:35
thanks dave I gave him a coil to try and we will try the jumper
