Schock Absorber Seat
Roger Gehring
09-09-2002 11:55:19
Can anyone tell me where to purchase a new original schock absorber for my 8N seat?
Jerry/LA
09-10-2002 19:58:17
 Re: Schock Absorber Seat in reply to Roger Gehring, 09-09-2002 11:55:19
I dont know about a sChock absorber, but I found a shock at a Mack dealer, they matched it up off the shelf, The man I bought it from said it was a discontinued shock that had been there so long it was not in enventory. fit fine and works but it does not have a dust cover only the body with an eye attached to the stem opposite the body!!
Ed Gooding (VA)
09-09-2002 13:39:31
Hey Roger. Someone here did some research on this a while back, and shared the following info about the Monroe E-Z-Ride Seat:
Monroe E-Z-Ride Comfort Seat Option
I tried last spring to find this shock with no luck. My shock had stamped the following information:
Monroe Auto Equipment Company
Monroe, Michigan USA
patent number 2,004,380 & 2,078,364
10B8
OF6-E1
18144
Dimensions of the shock follow:
6.38” compressed center to center
8.00” extended center to center
2.06” large cover diameter
1.68” small body diameter
Retaining ends are as follows:
1.44” OD
1.00” BORE
0.94” WIDE
The number for Monroe is 1-800-879-0540
I also tried a couple of different auto stores with no luck. I finally just painted the old one and put it back on.
I did replace the rubber bushing with some pieces I got from NAPA. The rubber bushings were 2-piece rubber snubbers, number 215 for 0.62 shoulder bolt. I did have to modify the rubber pieces to fit the taper inside of the shock mounting bore.
The Monroe E-Z Ride spec sheet I have doesn't list any dimensions. But it does have part #'s.
9N/8N #16041
NAA #16074
Monroe also made seats for: AC, Case, Corbitt, Co-op, Custom, Farmcrest, Ferguson, Gibson, IH, Inter-Continental, JD, Long, Massey-Harris, MM, Norse, Ostenberg, Oliver, & Sheppard. The brochure states they sold over 600,000 in 4 years.
Third Party Image
Hope this helps..... ..... .Ed
'52 8N475798
Darrel(ok)
09-09-2002 12:44:18
Were the original shocks patterned after an existing automobile shock? Has anyone ever asked at the link below? I don't have the answer either.
no . . . Dell (WA)
09-09-2002 12:29:01
Roger..... ...this question comes up frequently, and so far, no one has been able to come up with any sort of replacement that I know about..... ....Sorry, Dell
Farmer(Ga)
09-09-2002 18:05:05
 Re: Re: Schock Absorber Seat in reply to no . . . Dell (WA), 09-09-2002 12:29:01
Roger,some time ago one of our forum members posted he took his off and found a replacement at a truck stop.Of coarse it was'nt org.but it worked.I have one too and its worn out,I just havent went out looking for one.I dont think monroe makes them any morebut you could contact them with the part # Ed previded. Good luck and let us know if you find out anything. Farmer(Ga)
bg
09-09-2002 18:21:06
 Re: Re: Re: Schock Absorber Seat in reply to Farmer(Ga), 09-09-2002 18:05:05
I contacted Monroe with all the data and they could not help. I contacted several air-ride seat mfg's and they could not help. They are very similar to the shocks in some air-ride seats, but I haven't been able to track down a source yet.
