Order Ford 8N Parts Online
8n cuts out
rich in n minne
09-09-2002 12:39:42
Hi everyone:
Have a 48 8n. When used with my 6ft woods mower, it will mow for hours just fine. However, If I put a moderate load on it like cultivating or discing or plowing, it will start to cut out after about an hour of work but idles just fine. As a matter of fact, it will operate with out cutting out at about 2/3 throttle and only cuts out at full throttle or slightly less. Gas flow seems fine. I have put my hand on the coil when this happens and it is cool to the touch. I changed plugs and that did not make any difference. Plugs looked like they had been firing just fine. Any thoughts out there?
Thanks for your assista
Wayne Mo
09-10-2002 09:35:18
 Re: 8n cuts out in reply to rich in n minnesota, 09-09-2002 12:39:42
bg is right, the loads of the plow are a lot greater than the mower. If the plugs looked ok, I would suspect the main jet is not opened enough. Did you try just simply turning it out a half turn or so.
Evil Steve
09-10-2002 07:51:55
A "dying under load" problem is best first isolated by making sure your ignition system is at optimum. Check point/rotor/cap condition and gap and all electrical connections first. Then move on to governor/fuel etc. troubleshooting.
I recommend this to everyone: until you are SURE your ignition system components are proper, it is exponentially more difficult to isolate other problems. It doesn't take much decrease in ignition performance to cause you chasing all sorts of ghosts. Verifying/fixing ignition deficiancies does not take much time and needs to be done more regularly than many realize.
bg
09-09-2002 12:47:47
I'd look at the governor or centrifugal advance. The disk or plow is putting more load on the engine. If those two areas are fine, I'd do a thorough carb cleaning and adjusting.
