8n/Wagner Loader Control Valve
Info for the good of the cause
Popster (MD)
09-09-2002 14:15:08
Here’s an update on my search for a loader valve for my 8N tractor with a Wagner Loader. The loader has a double acting cylinder on the bucket and single acting cylinders on the arms.
The Cross C-series valve featured in Northern Hydraulics is not the correct valve for this application. The C-series is designed for non-lifting/loader applications.
I went to the Cross site,>Link
I called 620.324.5525 and spoke to Greg who is absolutely competent and knowledgeable. He gave me the following numbers for a valve designed to specifically work in this application:
BA 231AAG3EA0 for valve with single acting cylinder on the left
BA 213AAG3EA0 for valve with single acting cylinder on the right.
List price is $229. You can order it from a distributor (Greg supplies list) so you can use credit card and save COD or order directly from factory. From factory COD charges and shipping apply.
Hope this helps someone.
