Winter Tractor Projects
Arne
09-09-2002 14:45:46
I was thinking about all the stuff I need to do to my tracor this winter and thought I'd make a list and ask what you folks are planning on.
My list:
Oil Change
Tune Up
Rebuild Lift Assy Top cover, cyl, valves, follower pin
Fix RH lift pin (Pull LH Axle Trumpet)
Fix PTO assy (Split Tractor Behind Tranny)
Live Thang
Steve (Magnolia, TX)
09-10-2002 06:54:09
 Re: Winter Tractor Projects in reply to Arne, 09-09-2002 14:45:46
Ahhhh, winter...
Hopefully I'll have my 8N put back together by then. Winter's when it finally gets cool enough to do stuff outside.
(assuming the tractor's back together) I'll;
Clean the barn
Brush hog the pasture
Clean the barn
Cut some new pasture (with the brush hog)
Clean the barn
Cut firewood
Clean the barn
Build fence (?)
Clean the barn
Seems like I just can't keep that danged barn clean!!
Paul R.
09-10-2002 03:27:31
I've got a lot to do BEFORE winter!! Gotta get the backblade out, clean it off and get a couple of good coats of hi-gloss paint on the mouldboard. Snow wouldn't scour worth a darn last year.
Planned on replacing my broken rear differential casing, but that would mean tearing down the entire rear of the tractor for a week or two. We'll see. Might make a good winter project.
Willy-N
09-09-2002 21:52:12
Done most of those allready I am getting ready for the Snow to cold to work on the during the winter!! Mark H.
Jack - Illinois
09-09-2002 17:14:07
Put Sta-Bil in the gas and lock it up
Go to Florida
cargocult
09-10-2002 07:16:43
 Re: Re: Winter Tractor Projects in reply to Jack - Illinois, 09-09-2002 17:14:07
third party image
Me too!! Except I'm planning to go to the Philippines.
ThompsoN - my winter list goes....
09-09-2002 15:26:33
- push snow
- push snow
- push snow
- fill gas tank
- push snow
- pull wife out of ditch (push snow on way back to shed)
