Noise going down hill
RussMO
09-10-2002 07:32:59
I posted this eariler, but having problem locating noise. With PTO engaged, brush hog running, going down hill, a chatter is coming from somewhere. It will only appear going down a small hill. I thought it might be PTO bearings, but not sure. Any suggestions?
Thanks
I suspect...duey in MN
09-10-2002 11:02:33
 Re: Noise going down hill in reply to RussMO, 09-10-2002 07:32:59
that there is a rotary harmonic that is developed going downhill when rear wheels are driving the tractor's engine and PTO/hydraulic pump, that just isn't there when the engine is doing all the pulling. The gear and shaft loading is just not the same. Is it harmful? Probably not, these circumstances don't go on for very long. Even with a big heavy flywheel, a 4 cylinder isn't a 'smooth' engine.
My '46 2N has sounded that way from my earliest memories, and it was LOTS newer in the '50's!
Dell (WA)
09-10-2002 09:18:03
Russ..... ...if you are using (and you should be) an Over Running Coupler on your PTO output shaft to drive your brushog, I'd guess your noise is the ORC working. You do greese it don't you? ..... ....Dell
RussMO
09-10-2002 12:46:07
 Re: Re: Noise going down hill in reply to Dell (WA), 09-10-2002 09:18:03
It has been greased on a regular basis. Could the overrun coupler be faulty?
yes . . . Dell (WA)
09-10-2002 12:49:07
 Re: Re: Re: Noise going down hill in reply to RussMO, 09-10-2002 12:46:07
Russ..... ....yes, the ORC can be faulty, $60 cheap..... ...Dell
RussMO
09-10-2002 12:50:52
 Re: Re: Re: Re: Noise going down hill in reply to yes . . . Dell (WA), 09-10-2002 12:49:07
Thanks for your help
You need to tell us... Evil Steve
09-10-2002 08:03:50
... first whether you are using an overrunning clutch on your PTO. If not, get one because the chatter you hear is the hog trying to take over your tranny clutch and spin that clutch at it's whim rather than your engine taking control (causing sliping in your cluch). BAD BAD for your clutch and PTO plus the momentum of the hog is gonna be hard to stop.
If you DO have an ORC, the chatter STILL could be tranny clutch slipping due to worn pressure plate or improper clutch adjustment (check that first) or by a worn PTO.
RussMO
09-10-2002 12:49:35
 Re: Re: Noise going down hill in reply to You need to tell us... Evil Steve, 09-10-2002 08:03:50
If its not the overrun coupler, I suspect it is the clutch. It probably is due for a clutch overhaul. Thanks for the help.
