Order Ford 8N Parts Online
8N POINTS
RON (GA)
09-10-2002 17:47:08
Recently I changed out the points and condensor on my '52 8N...it ran fine for a week or two, then yesterday while doing light mowing it started missing and quit...we checked the points and they were completely closed and the inner contact arm was raised higher than the outer one by about 1/16 inch. The points were also burned pretty bad.....could I have been sold the wrong points and what would make them close up and move up like that? Any help would be appreciated....
Don (NC)
09-11-2002 11:42:48
 Re: 8N POINTS in reply to RON (GA), 09-10-2002 17:47:08
You say the inner arm was higher than the outer one. Do you have the washer and tiny cotter pin through the pivot post to hold it down?
RON (GA)
09-12-2002 16:47:57
 Re: Re: 8N POINTS in reply to Don (NC), 09-11-2002 11:42:48
Everything was lined up and correct when we put the points in....I checked the Voltage Regulator today and the inside was fried....burn marks on the cover....I bought a new one toady....plan on replacing everything this weekend....thanks for all the info Don, Dell, and BG....I'll let you know how it runs Sat.....thanks again....RON
bg
09-10-2002 17:49:59
There are some inferior points on the market. A lot of guys like Blue Streak, which I think NAPA carries. You might want to put a small drop of loctite on the screws that hold the points to the breaker plate.
Dell (WA)
09-10-2002 19:11:21
 Re: Re: 8N POINTS in reply to bg, 09-10-2002 17:49:59
Ron..... ..what BG sez..... ..and also be aware that the #8 X 3/16 plated brass points screws actually wear and loose their thread grip but will look kinda OK. I'd suggest replacing them. DON'T USE 1/4" screws. mucks up your centrifical advance weights under the points plate..... ...Dell
