Click sound coming from the solenoid
Rick T
09-11-2002 16:21:46
My 8n will not start, the solenoid will click once with each push of the starter. The tractor does not turn over. The amp gauge needle does not move when the key is turned on, it used to ,but will when the lights are turned on.Please advise. Thanks Rick T.
Lou VA
09-12-2002 06:30:43
 Re: click sound coming from the solenoid in reply to Rick T, 09-11-2002 16:21:46
I had a similar problem and took Dell's advice about keeping all connections shiny and bright. Removed the cable connections to the starter, cleaned them with an abrasive to get them to shine and reconnected them. The starter went right to work like it should. This is the cheapest test and should be done first.
Jim
09-12-2002 05:31:53
I would check and make sure the starter is not locked up. Put the tractor in 3rd or 4th gear and rock the tractor back and forth. This will unstick the starter if it is locked up.
Good luck,
Jim
Dave OH
09-11-2002 21:16:44
As said batt., cables, or a bad starter switch.
You can hot wire it to bypass the switch if you know how. Remember when you were a kid? Ah, maybe I was a bad kid.
Dave OH
Fast Ed Ohio
09-11-2002 21:15:17
Id say, clean the battery terminals real good and go from there .
Wayne Mo
09-11-2002 20:33:32
YOu have a dead battery or your cables are bad. A voltmeter will show you where you lose the 6v. Clicking solenoids always mean low voltage to them.
scottNky
09-11-2002 17:27:04
dead battery, old bAttery, dirty battery posts, dirty battery cables, not makN contact.. wiring needs to be cleaned. .New battery? needs chargN.. check volage regulator..strictly electrical ..Got a voltmeter,? How about one of those batter testers?
$42 bucks will get U a New battery, but if your chargN system isN't up to par..uh, well. ok
