Rear work light
Ole
09-11-2002 18:56:56
Almost done restoring my 51 8n and am getting around to some of the smaller items. My rear worklight is original but is burnt out. When I took it apart I discovered that the light is not a sealed beam but it does not have a replaceable bulb. It appears the bulb was originally soldered into the back of the lamp. It is stamped TRACTO-LITE on the lens and also has a FORD logo on the lens, Does anyone know if there is a way to modify this to accept a bulb or if there is anyone that carries a replacement.I would like to keep the TRACTO-LIGHT lens for originality.
THANKS
Ole
Bill from MO
09-12-2002 04:15:18
 Re: Rear work light in reply to Ole, 09-11-2002 18:56:56
Ole,
I have in the past unsoldered old bulb and replaced and resolder with new bulb using a 6 volt bulb with single element. Bulb is the same as the back up light used on your older model cars.
Soundguy
09-12-2002 04:15:11
Well.. if it is indeed soldered in... then it can be unsoldered.. Then all you need to do is find a suitable light ( 6v right? ) and make it fit in the housing. You might need a few scraps of tin to make mounting hardware with for the new light if it has a smaller base diameter, etc.. or even enlarge the hole.
A dremel tool, or patience with a file, and a small propane torch seem like the right tools.
Never done this myself.. but don't see why it can't be done.
Remove any orings, or seals in the 'non-sealed' beam ( behind the lense? )if any are present... don't want to melt them.
let us know how it went / goes.
Soundguy
