Ammeter....
Patrick (Sussex
09-12-2002 11:59:48
The ammeter on my 50 8N flutuates wildly. On startup, it shows steady positive, once you rev her up, it starts fluctuating from -0- to the high end of the scale. The fan belt is new and properly adjusted, original 6 volt configuration and the battery seems to be staying charged. Is this a case of since it ain't broke....? but I kinda can't help myself.
Thoughts appreciated...
Patrick (Sussex, NJ)
09-12-2002 13:37:38
 Re: Ammeter.... in reply to Patrick (Sussex, NJ), 09-12-2002 11:59:48
and here I thought I was going to get away without messin with the electrics on my 8N.....
I haven't run it enough to know whether I'm boiling water....it was a little low when I bought it....
Can I get generator brushes at an auto parts store, or are they a Don B order?
Thanks for the help...
Dell (WA)
09-12-2002 13:59:01
 Re: Re: Ammeter.... in reply to Patrick (Sussex, NJ), 09-12-2002 13:37:38
Pat..... ...most "real" autoparts stores, (you know the one's with greasy machine shop out back) will have generator brushes. You just haffta ask..... ....Dell
09-12-2002 14:23:26
 Re: Re: Re: Ammeter.... in reply to Dell (WA), 09-12-2002 13:59:01
Thanks, I appreciate it.....
Dell (WA)
09-12-2002 13:00:19
Pat..... ...something it "BROKE" and it need fixing before it gets more expensive.
You have eather a bad brush in your generator OR you have a bad voltage regulator.
Brushes are cheep ($3) and eazy, I'd start there. But I'd also consider replaceing the V/R ($25). Don't forget to re-polarize your V/R-generator..... ..... ...Dell
Dave OH
09-12-2002 12:56:04
Sounds like a bad voltage regulator. See if you are cooking water out of the battery.
Dave OH
